JD 2032R engine Idle speed
   / JD 2032R engine Idle speed #1
Novice Brit
Bronze Member
Suffolk UK (no land) Charente France (with land)
JD 2032R
Wondering if anyone can tell me what the correct engine Idle speed is for the JD 2032R? The manual refers to an operating range of 1225rpm upwards but isn't specific about ideal speed - 1225?.
Mine is idling at around 1400rpm, this seems a bit high but wouldn't have worried me if I wasn't having a little trouble selecting High or Low Transmission, have checked the transmission oil and this is fine, perhaps new JD's are a bit 'sticky'?
   / JD 2032R engine Idle speed #2
The difference between those idle speeds won't make a difference in changing the range gears. What helps with the sticky gears is a very slight rocking between forward and reverse pedals.
   / JD 2032R engine Idle speed #3
Or you can just rock yourself back and forth in the seat a little and it'll go into gear.
Wright Sentar (A50120)
Bobcat 14" Hydraulic Asphalt Plainer (A52384)
Bobcat 14"...
BUYERS PREMIUM & PAYMENT TERMS (A54313)
BUYERS PREMIUM &...
Pallet of miscellaneous chains  (A52384)
Pallet of...
2018 KENWORTH T880 (A53843)
2018 KENWORTH T880...
2018 Toyota Tacoma Crew Cab Pickup Truck (A51692)
2018 Toyota Tacoma...
