Jd 2030
   / Jd 2030 #1
klc336
international b414
Hey guys, Im trying to identify whether my 2030 has the 8gpm or the 18 gpm hydraulic pump. Is there an easy way to figure that out? Thanks
   / Jd 2030 #3
From the Green Tractor forum:
1.38 ci pump
The cover on the front of the pump(retained by 8 hex bolts) will have an "Indention" in the center.
NjY5N2ViYWI1MmY5NzY4YWZiMzA5MmEwZWI5NzViOGbZjx_BEJoiPu-2Dde4ZGz6aHR0cDovL21lZGlhLmFkc2ltZy5jb20vZmEzMWJmMDhiOWQyNWNjMzk2ZmQ4YWMzMWIzZWEyOGI2YjAzNzQ2NjhlMGMzMDRmN2U0ODI4ZDY5ZjM0YjMwYS5qcGd8fHx8fHw3MDB4NTI1fGh0dHA6Ly93d3cuYWR2ZXJ0cy5pZS9zdGF0aWMvaS93YXRlcm1hcmsucG5nfHx8.jpg
2.4 ci pump
The 2.4 ci pump has 4 hex bolt retaining the cover. The cover is flat
2014 Ford Escape SE, Eco Boost (A52384)
2014 Ford Escape...
40' CONTAINER (A51248)
UNUSED WOLVERINE ADB-13-1218R HYD AUGER (A51248)
UNUSED WOLVERINE...
PRO WORKS PWFF LOT IDENTIFIER 15 (A53084)
PRO WORKS PWFF LOT...
2014 CAT  299D TRACKED SKID STEER (A53843)
2014 CAT 299D...
2002 Genie S-125 4x4 125ft Telescopic Boom Lift (A52377)
2002 Genie S-125...
