JD 2030 WIRING DIAGRAM
/ JD 2030 WIRING DIAGRAM #1
dhiettjr
JOHN DEERE 2030
I HAVE A gasoline JD 2030 yr 1977 that has no wires running from light switch to lights. i am installing new lights . the switch is a rotating switch with multiple positions. any one have a wiring diagram for this ?
/ JD 2030 WIRING DIAGRAM #2
er, i don't have a diagram, but you don't want to wire from the switch directly into the lights. the lights will require too many amps to run thru a switch. You'll need to have the switch run a 12volt relay and the lights will wire into the relay.
the relay is basically a magnetic contactor that closes when the switch is turned on. it takes nearly zero amps.
You can use a continuity tester to test the different terminals on the switch as you turn the switch . this way you can figure out which terminals you need to use.
2020 Club Car Carryall 700 Gas Utility Cart (A61567)
2020 Club Car...
Location Info Please
KOMATSU FORKLIFT (A63291)
KOMATSU FORKLIFT...
2025 48in. Farm Jack (A61567)
2025 48in. Farm...
2016 Nissan NV2500 Cargo Van (A61573)
2016 Nissan NV2500...
Vermeer 604 XL-Series (A62177)
Vermeer 604...
