JD 2030 broken drawbar mount?
   / JD 2030 broken drawbar mount? #1
SouthpawJim
Martinsville, IN
John Deere 2030; IH Farmall 656 RC
20140324_192240.jpgFound something today on my dad's old tractor. At the front of the drawbar there is a bracket and pin that hold it in place, up under the tractor. One side of the bracket is broke loose. Now I know my dad had used it to bushog with a while back, so I'm not sure when it happened. He's not here any more for me to ask, so I'm wondering if there is a fix. Looks like it keeps it from sliding forward and backwards, the center bolt is still in place, but. Well let me just show a picture.
Any thoughts would be appreciated.
   / JD 2030 broken drawbar mount? #2
Ouch that's ugly. Short of replacing the housing (big expensive job) you might find a good welder that can fix it for you. Short of that maybe you can design a bracket that comes off some other bolt holes kind of like a crossmember. Good luck.
   / JD 2030 broken drawbar mount? #3
Likely why the tractor was used for bush hogging. I wouldn't use the drawbar unless you secured it.
Take the drawbar off until repaired. You or someone not knowing the situation, might break the casting to make the tractor totally unusable.
   / JD 2030 broken drawbar mount? #4
I agree either R&R trans case or find a talented welder to repair it.
   / JD 2030 broken drawbar mount? #5
I would think tractor is already unusable,should have lost most if not all hyd oil.
   / JD 2030 broken drawbar mount? #6
Looked again ,the holes are bolt holes,not going all the way into the case. My bad
   / JD 2030 broken drawbar mount? #7
I wonder what it took to break that? I have done some hard pulls on tree stumps with my 2030.
The retaining parts for the drawbar do not look correct
   / JD 2030 broken drawbar mount? #8
That is going to take a lot of metal buildup to fill in those casting holes then drill and tap. Its not going to be a cheap repair regardless of how it is done and likely wont ever be as strong as the original. I think on that old tractor, best to just stop using the belly mount drawbar. You could get one of the fixed 3 point hitch attachments like folks use to put a ball on to pull a trailer with using the small CUT and pull what you needed from that
   / JD 2030 broken drawbar mount? #9
I like oldtractorfixer's idea, since you have the mower already. Those holes have been broken out for some time by the look of them. Fab a new stronger bracket for some other threaded locations so you can keep using the setup you own.
Jim
The only thing I can think is that the rear of the drawbar bottomed out and pushed it out in the front.
What about drawbar attached to 3 point? I would make sure it would be set at standard draw bar height, and not given a chance to raise into the pto.
Diesel Forklift (A51691)
Diesel Forklift...
2018 INTERNATIONAL LT625 (A52472)
2018 INTERNATIONAL...
2006 Ford F-150 Pickup Truck (A51692)
2006 Ford F-150...
2- 30 X 42 TRIANGLE PIPE RACK (A52472)
2- 30 X 42...
43029 (A51691)
43029 (A51691)
80in HD Tooth Bucket with Side Cutters (A52748)
80in HD Tooth...
