JD 2025 power steering isnt workin. where and what fluid do i use
   / JD 2025 power steering isnt workin. where and what fluid do i use #1
Daniel01
Pine City New York
John Deere 2000
   / JD 2025 power steering isnt workin. where and what fluid do i use #2
On the 2025R, power steering is supplied to the tractor through dual hydrostatic pumps, which supply power to the steering and implement circuits. - From John Deere Home Page Redirect
I would check the hydraulic fluid level. Should be a yellow dipstick somewhere in the back. If its full you may have a clogged screen or its possibly time for a fluid and filter change.
   / JD 2025 power steering isnt workin. where and what fluid do i use #3
No, The 2025R has a single hydraulic pump, 2032R has two separate pumps.
John Deere claims 2025R on the website it has 2 pumps, but looking one over at the dealership... There website is wrong, Someone made an error.
   / JD 2025 power steering isnt workin. where and what fluid do i use #4
2025R has a dual pump. Look at parts key #4
   / JD 2025 power steering isnt workin. where and what fluid do i use #5
Oh yeah which fluid. Use Genuine John Deere Fluids either Hy-Gard or Low Viscosity Hy-Gard depending on the weather conditions you live in
Thanks, by looking at the site glass I need to add fluid,, thanks for the help
   / JD 2025 power steering isnt workin. where and what fluid do i use #8
   / JD 2025 power steering isnt workin. where and what fluid do i use #9
378688 (A51573)
378688 (A51573)
TEST BID LOT (A50775)
2017 FREIGHTLINER M2 BOX TRUCK (A52141)
2017 FREIGHTLINER...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52577)
2018 FREIGHTLINER...
2019 RAM 3500 (A52472)
2021 Club Car Carryall 500 Utility Cart (A51691)
2021 Club Car...
