JD 2020 Rockshaft control and Quadrant???
   / JD 2020 Rockshaft control and Quadrant??? #1
tech141
Bronze Member
Belleville, IL.... for now. 60 acres just South o
JD 2020 with FEL
Does anyone have pics of a properly configured/assembled JD 2020 Rockshaft control lever and quadrant? I don't believe mine is 'complete', there are no detents/stops and the lever will move on it's own from a low to high position unless I jam it to the floorboard. Looks like the lever has been bent approx. 2 inches from the quadrant face and there is nothing keeping it in any set position.
I don't have a pic of mine right now, and the tractor is 3 hours away. I will be heading out to the property next weekend and will get pics for comparison then.
In the meantime, if anyone has a pic of a known good one, I would appreciate you posting it.
Thanks!
Mike
   / JD 2020 Rockshaft control and Quadrant??? #2
It sounds as if you are missing the friction device. Items 8, 10, 11 and 21 is a pin, washers and spring washers that engages the lever and the slot in the quadrant. The spring washers apply a drag to the quadrant so it stays in place.
   / JD 2020 Rockshaft control and Quadrant??? #4
Parts 7 &13 are the stop that you can set for reurning to the same spot each time after raising when you lower again.
   / JD 2020 Rockshaft control and Quadrant??? #6
the lever will move on it's own from a low to high position unless I jam it to the floorboard. Mike
If control lever moves on it's own while engine is running then I'll bet these are missing or not snug enough.
11M7081 PIN, COTTER ADD 0.17 USD 0.17 USD
parts key #8 T26625 PIN,FRICTION View/Update 11.68 USD 11.68 USD
parts key #10 24M7298 WASHER, METALLIC, ROUND HOLE 0.48 USD 0.96 USD
parts key #11 T22877 WASHER,SPRING ADD 0.79 USD 1.58 USD
   / JD 2020 Rockshaft control and Quadrant??? #7
Not sure if it's the same as a 2030. I could get a picture of it. Mine slowly rises. might be the spring washer is worn out. Never thought of replacing it until now.
   / JD 2020 Rockshaft control and Quadrant??? #8
Spring(friction) washers put just enough resistance on control handle causing control handle to stay where it's placed to overcome the spring inside rockshaft housing .
   / JD 2020 Rockshaft control and Quadrant??? #9
My lever broke off and lost
Any pics of the neural postion
I need to make a new lever and weld it onto the shaft
2018 Dodge Charger Sedan (A50324)
2018 Dodge Charger...
Unused 2025 CFG QNT50R Mini Excavator (A49461)
Unused 2025 CFG...
Unused 2025 CFG QK18R Mini Excavator (A49461)
Unused 2025 CFG...
2017-2023 Chevrolet Silverado Pickup Truck Bed (A49461)
2017-2023...
Chevrolet C8500 Flat Bed with a Moffet Kit (A51039)
Chevrolet C8500...
2011 IC Corporation PB105 School Bus (A49461)
2011 IC...
