JD 2020 Prestolite Distributor
   / JD 2020 Prestolite Distributor #1
red35x
hudson, wi, usa
Kubota B2910
Have JD 2020 gas with prestolite distributor ibt 4101 S. It is jd part # AT21351. The gear on the drive shaft stripped and can not find just the gear. It is Jd part # AT21721 for kit that has gear, pin and shims. or AT21722 for just the gear. The gear is a prestolite part 90-597. I can find rebuilt distributors for upwards of $900 but I only need the gear. Does any one have any suggestions as obtaining prestolite parts, used gear, etc. etc. etc. I am exhausting all sources. THANKS to any one with info
   / JD 2020 Prestolite Distributor #2
   / JD 2020 Prestolite Distributor #4
Good deal..!!
2010 NEW HOLLAND B95 BACKHOE (A50854)
2010 NEW HOLLAND...
2006 INTERNATIONAL 7600 T/A DUMP TRUCK (A51406)
2006 INTERNATIONAL...
Pump Jack with Battery (A49461)
Pump Jack with...
Rhino 116 Flex Wing Offset Disc Harrow - Heavy-Duty Tillage Tool - Selling Absolute, No Reserve (A51039)
Rhino 116 Flex...
Bus (A50323)
Bus (A50323)
Pallet Fees (A50774)
