JD 2020 Brake lining replacement
   / JD 2020 Brake lining replacement #1
bprzyw
Madison Township, PA
JD 2020
Hi all,
Got me a 19xx (serial tag rusted off) yea JD 2020. Needs new brake lining. Anyone have any idea how many linings there are? one each side? Or how to get at them? Got lots and lots of brass in my screen and filter. Want to get this fixed before anything gets damaged in the hyd. area. Thanks!!!!!!!!!!!
Bernie:thumbsup:
   / JD 2020 Brake lining replacement #2
Each rear axle & housing needs to be removed from tractor.
1 AT26290 LINING 1 - XXXXXX (SUB AT63106 AND L31016)
2 T28177 BRAKE DISK 1 - XXXXXX (SUB L31016 AND AT63106)
3 AT26289 RING 1 - XXXXXX (SUB L31016 AND AT63106)
4 AT22034 BRAKE DISK 1 XXXXXX - (SUB AT63106)
5 L31016 PLATE 1 XXXXXX - (SUB FOR T38063 OR T46728)
6 R50704 SEALING WASHER 1 (SUB FOR T22103)
7 R50703 WASHER 1 (SUB FOR T22102)
Thanks Tx Jim,
Dang, this sounds like a big job.....
Was afraid I was going to have to do this. Do I need the rivet / de-rivet tool for this job also? Or is the lining already riveted to the plate? Do I need 2x the parts for each side? ( 1 thru 7 for right, and 1 thru 7 for left) If I unbolt the axle housing, can I slide the entire assembly off of tractor? (wheel,axle,housing) without taking off the tire/rim? And I need to pull the rops cross member.
   / JD 2020 Brake lining replacement #4
I think the axle/housing assembly would be easier to handle, especially when reinstalling with the wheel and tire removed. Good luck!
Zebrafive....Thanks, was thinking the same. Its just that the tires are filled, and I do not have something to move the tires with.
   / JD 2020 Brake lining replacement #6
As you keep the tire upright you should not have a problem. You will need a helper. Is there any place you can roll one to and lean it against? Might want to tie it off too.
2017 JLG Skytrak 6036 6,000LB 4x4 Rough Terrain Telehandler (A50322)
2017 JLG Skytrak...
2016 Case CX55B Mini Excavator (A49461)
2016 Case CX55B...
2006 GMC C8500 Altec AM547 50ft Material Handling Insulated Bucket Truck (A50323)
2006 GMC C8500...
NEVER USED FECON 74in Deck Mulcher FDM74 (A51039)
NEVER USED FECON...
2015 Ford Explorer AWD SUV (A50324)
2015 Ford Explorer...
KODIAK 10' HD ROTARY MOWER (A51406)
KODIAK 10' HD...
