JD 190C Engine Pops
   / JD 190C Engine Pops #1
CharlieTR
NE TX
Long LongTrac
I recently notice my 190C mowers engine started to make a small backfire sound when the PTO is not engaged and when the throttle is at full speed.
It never did this before. I was wounder what to look for. Thanks,
Charlie
   / JD 190C Engine Pops #2
Charlie,
You most likely have carburetor problems.
My 190C did the same thing last year. It only had 165 hours on it but it started to pop and spit and sputter at WOT and was just running really ragged.
I tried lots of things, from changing spark plugs to checking the flywheel key and even brightening the magnets on the flywheel, all to no avail. Then I started to notice it was only happening on one cylider, not both.
I learned that the carb on these Briggs engines is really two carbs in one housing. One carb for each cylinder. There is a plastic tube inside the carv with some plastic jets in the bottom. The jets have o-rings around them. Over time, the o-rings get hard and don't seal any more. In some cases, the o-ring will actually let the jet fall out of it's hole.
JD offers a kit, you can get a kit from a Briggs dealer cheaper, but I just replaced the whole carb. No one had a kit in stock, it was a Saturday and I HAD to finish mowing. JD didn't have a new carb. (thank goodness since they wanted $200 for one) Bought the same part # new carb from my local Briggs dealer for $125.
Hope this helps.
Mark
2017 Nissan Frontier Ext. Cab Pickup Truck (A51692)
2017 Nissan...
2021 CATERPILLAR 926M WHEEL LOADER (A52705)
2021 CATERPILLAR...
2014 Dynapac CC4200 Tandem Vibratory Roller (A52748)
2014 Dynapac...
2015 UTILITY VS2RS 53FT REEFER TRAILER (A53426)
2015 UTILITY VS2RS...
2007 FREIGHTLINER BUSINESS CLASS M2 T/A DUMP TRUCK (A51406)
2007 FREIGHTLINER...
HYSTER H55VM STRAIGHT MAST FORKLIFT (A51406)
HYSTER H55VM...
