JD 180 Regulator Voltage
   / JD 180 Regulator Voltage #1
bobsphotos
ME
JD 3320 Ford 641 Ford 861 Kubota L3400
Can someone tell me what I should have for a charging voltage when my JD 180 lawn tractor is running. I cannot determine if the battery is bad or if it is not getting a high enough charge voltage. Any help will be appreciated.
   / JD 180 Regulator Voltage #2
Normally charging voltage is between 13.5 - 14 volts. at operating rpm.
2014 Ford F-150 Pickup Truck, VIN # 1FTFX1ET4EKG11918 (A54865)
2014 Ford F-150...
Case-IH 370 Steiger (A53314)
Case-IH 370...
Ford F250 Pickup Truck (A51694)
Ford F250 Pickup...
1993 Ford F-150 Pickup Truck (A52377)
1993 Ford F-150...
2015 Ford F-650 TMA Attenuator Truck (A52377)
2015 Ford F-650...
