JD 175 Hydro neutral and brake adjustment
   / JD 175 Hydro neutral and brake adjustment #1
diggerjim
Sothern Illinois
Yanmar 2220D
I just (this saturday ) picked up a used JD 175 Hydro cheap at a garage sale. It runs and mows good but the neutral position is a little tricky, and it jumps forward when in neutral and the brake pedal has no effect so I assume they need adjusting. I searched 100 pages in this forum but did not find any info regarding my problem. I also searched the web for a few hours with no particular help. Anyone have ideas? I will be buying a manual but I need to mow now..........grass is growing..........its raining.........etc.
   / JD 175 Hydro neutral and brake adjustment #2
I'm having same problem. Does anyone have the answer to this?
   / JD 175 Hydro neutral and brake adjustment #3
I am in need of an answer to this question as well
   / JD 175 Hydro neutral and brake adjustment #4
If you follow the control level down, there are some nuts you can adjust. I forget exactly, but you can adjust it. Private message me your email and I can send you a copy of the instructions I have.
   / JD 175 Hydro neutral and brake adjustment #6
Hey Diggerjim and beenhere: thanks beenthee.I found out about how to adj brakes by following the linkage on the parts breakdown the 5/16 th nut (1/2 wrench size 1&1/2 turns solved the problem) going clockwise on the nut. Hey diggerjim I would start off with that adjuster and check the brake lock adjustment. Hope I haven't confused you Guys. If so get back to me.
2013 Ford F-250 Ext. Cab Pickup Truck (A42744)
2013 Ford F-250...
2002 Mazda Protege Sedan (A42744)
2002 Mazda Protege...
Kubota 6' Mower 3Pt (A44502)
Kubota 6' Mower...
HUSKY TOOLBOX (A45333)
2012 FORD F550 UTILITY TRUCK (A43004)
2012 FORD F550...
2011 19ft Avalon Pontoon Boat and Trailer (A44391)
2011 19ft Avalon...
