JD 165 problems
   / JD 165 problems #1
blueriver
Elite Member
S.E.Oklahoma
JD 5520 Montana 4340 Farmall Super A Montana 5720C
JD 165 simply quit mowing ... the blades quit turning. I could not upon examination see any problems ... shut her down to really get a look. Could not see anything out of the ordinary... tryed a restart and dead, nothing.
I only assume it has something to do with the electric clutch that engages the mower deck.
1 ... Anyone else have any experience with this?
2.... Any Fuses that I may be overlooking?
3 ... Any imput would be great ...
   / JD 165 problems #2
Is this a JD LA165? I'd look at:
* 20 amp fuse (raise hood and look on right side just inside cowling)
* PTO switch
* Seat switch
* PTO clutch connector and wiring
* Reverse pedal switch (reverse sensing)
   / JD 165 problems
* PTO switch
* Seat switch
Thanks Jim ... I had put that on the back burner, easy to do when its done for the season. While I was searching for info ... found my own post!!!!
Guess I need to remember things better!!
Kubota RTV-1140 4x4 Diesel Utility Cart (A55851)
Kubota RTV-1140...
2018 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2018 DRAGON 150...
Bigfoot Metal Stand Up Sign (A55758)
Bigfoot Metal...
2022 Toro Workman 07921 Electric Utility Cart (A55851)
2022 Toro Workman...
2024 KMC 7406 LOT NUMBER 11 (A53084)
2024 KMC 7406 LOT...
Flat bed utility truck with inline 6Cy engine (A55301)
Flat bed utility...
