JD 160 won't start once it is shut off warm
   / JD 160 won't start once it is shut off warm #1
mdsbuck
vineland New Jersey
JD 214, JD 210
Have a JD 160 with Kawasaki 12hp. Starts and runs fine. Once it is shut down it will not start. It cranks, has spark, and fuel. Tank is venting properly so no vaporlock. Motor does leak oil out of sump gasket. Could it also be leaking from a blown head gasket? Would this cause it to start only when cold. (This thing won't even start with a shot of starting fluid once warm) Should I do a compression test before starting then after it is warm and won't start? Anyone know what the compression should read?
2004 Ford F-250 (A53422)
2004 Ford F-250...
2018 FREIGHTLINER CASCADIA SLEEPER (A54313)
2018 FREIGHTLINER...
2006 Ford Taurus SE Sedan (A55853)
2006 Ford Taurus...
2006 Magnum 125 125kW T/A Towable Diesel Generator (A55787)
2006 Magnum 125...
Takeuchi Skid Steer (A52377)
Takeuchi Skid...
2012 Nissan Rogue (A50324)
2012 Nissan Rogue...
