JD 155C tossing belt
   / JD 155C tossing belt #1
rburke65
Canfield, Ohio
1979 Kubota DT245, and a 2006 JD 155C
Hello folks....have a 7...8 year old 155C mower that throws the blade belt on start up. Replaced the belt and same thing. Pulleys seem ok with a little play in the one idler. When I reinstall the belt and engage the electric clutch, the belt stays on 8 of 10 times. The other 2 times, I reinstall the belt, then I'm ok. Any suggestions? Thanks people for your help.
   / JD 155C tossing belt #2
Might look for a bad bearing in a spindle that is lugging down to loosen the belt. Also, might be time to go after that idler. It is a nuisance to be throwing belts.
UNUSED Clear Multi-wall Polycarbonate Pane (A53117)
UNUSED Clear...
2018 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A54607)
2018 FREIGHTLINER...
Electric Mobility Scooter (A51694)
Electric Mobility...
2016 Ford F-450 Cab and Chassis Truck (A51692)
2016 Ford F-450...
2016 Ford F-550 Palfinger PSC3216 4,000LB 2 Ton Crane Service Truck (A51692)
2016 Ford F-550...
Light Tower (A52377)
