Aug 7, 2014 / JD 1250 Rear Hydralics #1 D davidarowe New member Joined Aug 7, 2014 Messages 2 Location Lancaster, TX Tractor JD 1250 The rear 3-point hydraulics on my JD 1250 are pulsing and drop down as soon as I shut the tractor down. How hard is it to rebuild that area or are there some simple things I can check. The front end hydraulics work find.
Aug 8, 2014 / JD 1250 Rear Hydralics #2 Tx Jim New Member Joined Jan 26, 2007 Messages 10,291 Location Coyote Flats,Tx Tractor JD 4255/Kubota M7040 HDC More than likely either the 3 pt control valve or the rockshaft piston seal is leaking. The rockshaft housing will require removal to repair.
