JD 1217 haybine gearbox oil
   / JD 1217 haybine gearbox oil #1
Niji
southwestern Virginia
I've just gotten and rebuilt a 1217 JD mower/conditioner. It's running great, but I haven't hunted up a used manual yet. Anyone have info on checking gearbox oil levels, and type of gear oil recommended? I'd like to get that checked while in the mode and before 1st cutting.
   / JD 1217 haybine gearbox oil #2
All implement gearboxes Im familiar w/have fill, drain and check points. The full point is somewhere between fill & drain on the side of the box. All of my implements use sq head plugs so that might be a help in locating it. Instructions for my implements indicate the gearbox should be filled to the bottom of the full point. So once you locate the plug and remove it some oil should exit. That said theres no substitute for an owner manual...itll give location and oil type and you wont have to guess. :)
1999 CAT TH63 (A50123)
2009 40ft High Cube Refrigerated Storage Container (A51692)
2009 40ft High...
LATE MODEL JOHN DEERE EQUIPMENT AUCTION (A53084)
LATE MODEL JOHN...
2007 Reitnouer 40 Ton T/A Heavy Haul Flatbed Trailer (A52377)
2007 Reitnouer 40...
2015 Terex PowerScreen TrakPactor 320 Crusher (A50322)
2015 Terex...
NAPA 80 GALLON ELECTRIC AIR COMPRESSOR (A51248)
NAPA 80 GALLON...
