JD 1209 haybine advice
   / JD 1209 haybine advice #1
LondonDave
Bronze Member
Melbourne, Ontario Canada
John Deere 5410 MFWD, Case IH 5230 MFWD
I'm going to look at a JD 1209 haybine/mower condition/mow/co...whatever you want to call it on Wednesday. The price is right. I'm currently using a NI 251 sickle bar mower and it's just not working for me. I've read about issues with the 1209 wobble box. If the mount has been broken and repaired is it still not advisable to buy one? Can it be repaired properly? It's apparently been used up until last year. The seller is getting out of haying so he's selling it. What exactly should I be looking at with regards to the wobble box? I'm familiar with the knives and guards, etc. so I'll be checking that stuff over. Is there anything else I should pay close attention to?
Dave
   / JD 1209 haybine advice #2
On most wobble boxes there are four bolts that attach the gear box to the frame. Usually the bolts go straight up from the bottom but I have seen two attached from the side on a Macdon. Make sure those bolts are tight! If they've ever been loose you will see the paint worn off.
It's a bit of a mickey mouse design but I've been able to repair loose gear boxes by cleaning out the holes one at a time with brake clean and installing new bolts that have been generously coated with JB weld. Once the weld is hard they stay in place.
   / JD 1209 haybine advice #3
One of the major causes of the wobble boxes loosing is a bent cutter bar. This will work the box excessively trying to slide it back and forth. Make sure it is straight and chances are you should be fine.
   / JD 1209 haybine advice #4
Also loose arm on wobble box output shaft splines or worn pitman head pin. I would recommend walking away from a JD Mo-Co that the wobble box bracket had any welding done to mounting plate.
Thanks for the info guys. The seller tells me he has only owned it for a few years but it has never given him any problems and he hasn't done any work on it. Can all these things (loose arm, worn pitman head etc.) be easily checked?
International Tandem Dumo TRUCK (RUNS)(TITLE)(LOCAL TOWNSHIP) (A50774)
International...
2006 IC Corporation PB105 School Bus (A50323)
2006 IC...
2009 Peterbilt 384 T/A Wet Kit Day Cab Truck Tactor (A50323)
2009 Peterbilt 384...
2000 PETERBILT 379 TANDEM AXLE SLEEPER (A52141)
2000 PETERBILT 379...
2020 Kubota BX2380 (A50120)
2020 Kubota BX2380...
2015 FORD-750 XL SUPER DUTY DUMP TRUCK (A51406)
2015 FORD-750 XL...
