JD 110TLB won稚 move!
   / JD 110TLB won稚 move! #1
dicepilot
Cool Springs, AL
I have owned my tractor for 10 years now with hardly any issues. Yesterday after running it for about an hour using the FEL, I started using the backhoe. After a few minutes, I tried to creep backwards to reposition the backhoe and it would not move. Thinking it may be the seat switch, I flipped the seat and tried to move with the pedals. No luck. No warning code flashes or other indications. I messed with the seat switches and got the .-.- off seat code. Decided to bypass the seat switches and code went away, but tractor will not move. With pedal or creeper switch, the RPM will drop around 100 after a couple of seconds. Release pedal or creeper and RPM returns to where it was. Checked CB痴 and all are good. Any ideas on where to look next?
George
   / JD 110TLB won稚 move! #2
The transmission and creep function can't be used at the same time. If your pedals are engaged even a little, the creep won't work. I had a few different issues that were resolved by lubricating the forward and reverse pedals. Under the floor is a black cover with the springs and whatnot that react to the pedals being pushed. Lubricate the **** out of all that stuff then work the pedals a few times and then try the creep function again.
   / JD 110TLB won稚 move! #3
Great advise. I recently had this related problem and found it to be the seat switch. But while diagnosing I removed the entire pedal assembly and lubed. I decided to lube with silicon spray rather than a oily product as I didn't want to promote any dust to accumulate there. Food for thought.
Thanks for the advice. The pedals have been sticking, so I will lube them up good. Embarrassingly, I found the gear selector had been bumped out of A, but looked engaged. I had even bumped it forward while troubleshooting. After reading some other threads, I moved the gear selector to C, then back to A and it fully engaged. All went well yesterday and today, but while returning to the barn I got the Ground Speed Control fault code (...-). Guess that will be next weeks project.
Thanks again,
George
2016 Dodge Charger Sedan (A51694)
2016 Dodge Charger...
John Deere 1110 Field Cultivator - Heavy-Duty Soil Finisher for Precision Tillage (A53473)
John Deere 1110...
2017 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A51246)
2017 CATERPILLAR...
2007 Chevrolet Impala Sedan (A51694)
2007 Chevrolet...
ATTENTION PLEASE READ (A50123)
ATTENTION PLEASE...
Countyline Single Row Plow (A50123)
Countyline Single...
