jd 110 boom drop
   / jd 110 boom drop #1
wamsutta
massachusetts
jd 110 tlb,zetor 5245
It normal for the boom to drop down on the hoe when parked overnight,if not latched? The loader does not drop overnight.
   / jd 110 boom drop #2
I have an L39 that's in pretty good shape, 550hrs. The hoe will drop overnight if left unlocked. This never caused any functional problems that I know of.
   / jd 110 boom drop #3
Yes, that's a lot of weight for it to hold up, mine does the same.
I would recommend setting the boom down before leaving it a while anyway to let the weight off the rear tires.
   / jd 110 boom drop
sounds like good advise
   / jd 110 boom drop #5
Mine is either locked in place or setting on the ground, I never leave it unlocked and up as that puts unnecessary load on the seals. Best to leave the loader and stabilizers down too for the same reason.
   / jd 110 boom drop #6
My dirtbike mechanic friend says the same thing about the seals and I still don't get it considering how much pressure is on them when digging.
2007 Ford F-350 4x4 12FT. Flatbed Stake Body Truck (A48081)
2007 Ford F-350...
2010 Mitsubishi Fuso FE84D 16ft. Box Truck (A48081)
2010 Mitsubishi...
2001 GMC W4 CRANE TRUCK (A51222)
2001 GMC W4 CRANE...
2025 Swict 84in Bucket Skid Steer Attachment (A50322)
2025 Swict 84in...
2013 International DuraStar 4400 Altec AM547 50FT Material Handling Insulated Forestry Bucket Truck (A48081)
2013 International...
Tubing A500 Grade C 6in. SQ X 1/4in. X 28ft. (A50860)
Tubing A500 Grade...
