JD 1070 Tachometer Issues
   / JD 1070 Tachometer Issues #1
ndgregor
Wind Gap, PA
John Deere 1070
I have a JD 1070 tractor with a non-functional tachometer. There is no needle present in the instrument cluster for the tachometer gauge. Both fuel gauge and temperature gauge work fine, as does the hour meter. The backlights in the instrument cluster also do not work.
On occasion when running the tractor (usually at higher RPM) I can hear a noise I can best describe as a loud humming. It is intermittent and will go away after a few seconds. The previous owner told me that this was related to the tachometer not working, and that the noise was coming from the tachometer cable?
I am unfamiliar with how tachometers on these tractors work. My question is two fold- would I have to buy an entirely new instrument cluster ($$$) to get a functioning tachometer gauge and replace the back lights? Second question would be how to fix the tachometer cable to take care of the noise.
Thanks in advance,
Nick
   / JD 1070 Tachometer Issues #2
My John Deere 1070 does the same. I bought a tach cable hooked it up and got the same humming and occasional growling with the needle going backwards. After research the panel comes as one and hard to find
2018 Ford Explorer AWD SUV (A50324)
2018 Ford Explorer...
2019 Club Car Carryall 1700 4x4 Diesel Utility Cart (A48082)
2019 Club Car...
2014 Chevrolet Equinox (A50324)
2014 Chevrolet...
RIGID 150 PSI AIR COMPRESSOR (A50854)
RIGID 150 PSI AIR...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A49461)
2019 Allmand...
