JD 1070 4wd -ldr
   / JD 1070 4wd -ldr #1
grainger12002
Platinum Member
Pomfret,Connecticut
yanmar 336d w ldr,Cub,many attachments
I am looking for some feedback on the 1070 model.I am looking at one to purchase and wondering what you think. It only has 270 hrs on it,4cyl diesel,seems like a nice tractor.
   / JD 1070 4wd -ldr #2
The 70 series effectively replace Deere's 50 series tractors. I believe some things which were options on the 50 series (like power steering?) were made standard on the 70 series.
I think the 1050 was possibly one of the best machines Deere ever built. A Deere mechanic referred to them as "bulletproof" and most owners would agree. I have no reason to suspect that a 1070 with FEL wouldn't be a fine machine for you.
As to the hours, 270 is barely broken in, if that. Personally, I like the 1070's more than the 4200 I have. /w3tcompact/icons/hmm.gif If you like the machine and the price I'd say, "Go for it!" I think you'll be very happy with one. Good luck with whatever you decide. /w3tcompact/icons/smile.gif
   / JD 1070 4wd -ldr #3
I have a 1050 and it's very well built. I'd agree with your mechanic. I've put many hard hours on this machine (1000+ and counting) and the only thing I've replaced besides a front tire from thorns is the left front kingpin/spindle. I think that was a fluke of some sort as the problem hasn't returned. I'd also agree that the 70 series is just a newer version with a little more power. HTH
   / JD 1070 4wd -ldr #4
FYI:
I had a 1070, and was generally impressed with it. Traded up from a 955. Then moved on to a 4700 because I wanted HST again.
I might have kept it if the tranny was more friendly for mowing and similar tasks. Unfortunately during mowing, the pto should be kept at a constant rpm, which means ground speed is constant. If the mowing requires speed changes, e.g. around trees, etc, or short runs, or uphills, then there's a lot of shifting required. Also there's a significant speed gap between gears 1 and 2, which is where the mowing was the best. I found that gear 1 was frequently too slow, and gear 2 was too fast. Since mowing is such a frequent activity, these limitations of the trans got to be a real pain.
FEL work wasn't too bad -- the shifting becomes second nature, but the 4700HST sure beats it.
jim
   / JD 1070 4wd -ldr #5
Those are nice solid, reliable tractors.
2017 Dodge Ram 1500 4x4 Crew Cab Pickup Truck (A50323)
2017 Dodge Ram...
2017 Wacker Neuson ST31 Compact Track Loader Skid Steer (A49461)
2017 Wacker Neuson...
2018 John Deere 8370R MFWD Tractor (A50657)
2018 John Deere...
Unused Delta Crash...
2012 Ford Escape XLS SUV (A50324)
2012 Ford Escape...
2018 Wacker Neuson WL 38 (A51039)
2018 Wacker Neuson...
