JD 1050 3pt Hitch
   / JD 1050 3pt Hitch #1
jgbanshee
PA
JD 310SE, 4300, 5300, 5210, 450 Crawler, CAT D3B, Ford 2N, 5000, 4000su, 3610, 345C, 340B, 1100
I am trying to figure out how to raise the 3pt hitch all the way up. It raises so far with the normal 3pt control lever to the right then I have to raise it the rest of the way with the small lever behind the seat. Once I get it fully raised with the small lever, it goes about half way down and stays there. Can anyone advise me on what to do and what the small lever is for behind the seat?
   / JD 1050 3pt Hitch #2
The little lever under the seat is for the draft control. I also just saw the private message you sent me. If you send me your fax # I can copy my manual on that section as the book can explain it better than me.
2015 CATERPILLAR 326FL LONG REACH EXCAVATOR (A51242)
2015 CATERPILLAR...
Hyster H155XL Forklift (A48837)
Hyster H155XL...
2012 Mitsubishi Fuso FEC72S 16ft Box Truck (A48081)
2012 Mitsubishi...
2015 Ford F-450 Knapheide Service Truck (A48081)
2015 Ford F-450...
2016 Chevrolet Impala Limited Sedan (A48082)
2016 Chevrolet...
UNUSED Heavy-Duty D-Ring Shackle Set (A50860)
UNUSED Heavy-Duty...
