JD 1025r pricing and any comments
   / JD 1025r pricing and any comments #1
dmbtree82
PA
JD 1025r
Hi everyone,
I decided last weekend that I need a new tractor for a couple acres I just bought. It is on a pretty good slope and is an old farm field so its a bit rough right now. I bought a used x340 in the fall and after cutting it once decided this may not be the best thing for the job. I did an ok job cutting, but I'm afraid its going to take too big of a beating and not hold up. When we build we're also going to have a 300' driveway which will probably be a modified base for quite a while. My original thought was to buy an old tractor with a 3pt to help turn the field into some nicer grass for the family. My new thought was to just buy a subcompact now that will last me hopefully a lifetime.
I wanted to get something with a close by dealer and started to look at John Deere (1023 or 1025), Kioti (cs2410) and Kubota (bx2370). I checked out the JD first and the seat and cruise control with the 1025 seem to make that the way to go for me. I then looked at Kioti and the price was almost $3,000 less than the JD. I drove it around and there were a few things I didn't like; seat comfort, loader control position, throttle lever force needed, steps to get loader off and trouble getting it in gear. The sales guy said its common to have to give the kioti a little gas as you put it in gear (this seems a little odd). I left there pretty much ruling it out. I looked at the Kubota this morning and the price was about $2000 less than the JD. I couldn't take one for a ride, but the dealer offered to bring one to my land to try out (definitely bonus points). My concerns with the Kubota are seat comfort, lack of cruise control, loader removal, rocker throttle and a broken off knob. The knob was behind the right foot and if its broken on a new one, how well will it hold up in the long run? My friend also has an 1870 that is about 7 years old and has had a few problems with it (multiple fans shrouds broken and the floor is rotting through already; this is garage kept).
It seems the Kioti and Kubota I was looking at are actually more comparable to the 1023; does that seem accurate?
Are any of my concerns unfounded or is it all personal preference?
I got a price of $16,500 for the 1025 with 60" deck (no auto connect) and the H120 loader; is this reasonable or out of line? The dealer doesn't seem too willing to negotiate that price any lower.
Thanks for listening to me and looking forward to any comments.
   / JD 1025r pricing and any comments #2
Can't really go wrong with a BX or a 1025. I've driven tractors with twin HST pedals and others with the rocker treadle, and don't have a preference/problem either way. Cruise control is standard on some BX models, and optional (easily installed on others). I wouldn't let a broken knob be an issue -- the dealer should fix it before delivery. There are a lot of BX owners on here, and I don't recall broken knobs being a common thing.
Stuff like seat comfort and overall feel are personal preference, and something you need to evaluate for yourself (for example, some people don't like the rocker on Kubotas, some people don't like all the plastic body parts on the Deeres, etc). That's why it's so important to drive each tractor and really get an overall feel. Take your time, let yourself wander and explore the many options available. When I shopped for my first tractor a few years ago, I was sold on the Deere 1023 on paper/price, then the lousy seat pushed me to the 1026R (which later became the 1025R). Then I looked at the BX models but wasn't in love, so I drove a slightly larger Kubota B series and it was perfect. And priced just a few hundred more than the best deal I was seeing on a 1026R. I ended up with the B2920. The whole shopping process was fun and I learned a lot.
From what I see here, the best deals on Deeres and Kubotas are about 15% off MSRP. Sometimes rebates/incentives are part of the discount.
Good luck!
   / JD 1025r pricing and any comments #3
I don't think that crusie control is a big deal on a tractor, I know it has it's uses though.
Check out this video.
   / JD 1025r pricing and any comments #4
Have you checked out the Massey Ferguson GC series?
I think my thing with the knob was the position; its right behind my foot where it can easily get whacked and that appears to be what happened.
I looked at the Massey online, but don't have a dealer close enough that I want to deal with. Most of the time I will be using it for mowing so I think the cruise and easily removable loader are both important to me.
How important is the position control 3 pt? I think right now its not a big deal for me, but if I start finding out more and more uses for the tractor will that be something I wish I had?
   / JD 1025r pricing and any comments #6
Postion control is a big thing when you use rear implements that are dependant on hitch position for proper function. Inevitably you will need to temporarily raise (or lower) the implement for one reason or another and then lower it back to continue working.
Position control means you can get back to the exact right height without going through a trial and error series of approximations. The more frequently that happens, the more you benefit from position crontrol.
There is also the issue of hooking up implements, position control lets you move up or down in any increment you need and at any pace you choose. Without position control you move in discrete steps or jumps (i.e. inching).
Nick
   / JD 1025r pricing and any comments #7
I have used machines with cruise to mow. I don't see where it is beneficial. When you get to the end of your run you will need to disengage it to turn around.
The loader removes just as easy on the BX. Have you noticed that the JD does not have a center antiscalp wheel? It will scalp just like the video I posted shows.
Posistion control is nice but for no more than most people use a SCUT it is not necessary.
Thanks for the position control info Nick.
My current mower has cruise and I used it the whole time mowing pretty much. I'm pretty tall so any time I'm able to move my legs on long stretches the better; this basically makes cruise a necessity for me. I do have a scalping concern though. Anyone with the 60" deck on a JD have any input?
I'm also sure I can find the opposite video showing how the JD is better and the Kubota weaknesses.
   / JD 1025r pricing and any comments #9
Try posting in the JD section. There are allot of 1025 owners here that can give you some feedback on the cut quality, and on the quick connect deck, if you want to go that route. I also know that there are 3 different options for raising the deck. 1) mechanical. It relies on the 3 point arms. 2) Standard hydraulic. This relies on an independent hydraulic cylinder, but you have to plug it into the loader valve. 3) Independent hydraulic. This is a cylinder AND an independent electro hydraulic valve. IMO the 3rd option is the way to go.
There are also heavier seat springs available if they seem too light. You might want to check out Green Tractor Talk also.
   / JD 1025r pricing and any comments #10
I know someone that has a 1 series, it does scalp. The funny thing is a John Deere D140 that cost $2,000 has a center antiscalp wheel but the $2,000 7 iron deck does not have one. That is enough reason for me to not buy one if I wanted to mow with it. The deck on the 1 series only raises 4'' so you will have to take it off if you want to do anything more than mow. The BX deck raises to 6'' so you can actually do some work with it on the tractor.
You said you wanted a loader, did you see in the video that you can not raise and curl the loader at the same time but you can on the BX?
The 1 series a limited cat 1 3 point hitch, it is basically a cat 0 with cat 1 ball ends. It will not raise very high so you will be limited to what implements you can use. The BX has a Cat 1 3 point hitch. Implements for a full size tractor will work on a BX.
You said you are tall. Have you noticed how small the operators platform is on the 1 series? There is barley enough room for my size 13 foot to fit on it. The BX has a nice large operators platform.
The BX does have cruise control too.
2023 Bobcat T66 (A50120)
2023 Bobcat T66...
199049 (A51243)
199049 (A51243)
UNUSED EINGP SCL850 STAND ON SKID STEER (A54756)
UNUSED EINGP...
Polaris Side by Side (A50324)
Polaris Side by...
Kawasaki NR (A50324)
UNUSED LANDHONOR MAP-16-24W MINI MOUNT PLATE (A54757)
UNUSED LANDHONOR...
