JD 1020 PTO Quill removal
   / JD 1020 PTO Quill removal #1
Les8N
Rincon, GA
1949 8N, 1967 JD 1020
Hi all,
My first post: My Dad has a 1967 JD 1020 that we have been working on for one thing or another in the last year or so. The latest problem is trying to remove the PTO quill to replace the seal. The thing seems to be seized in the bore. The three bolts are out and I have tapped on it with wood blocks and cannot get it loose. I called a local JD dealer and they mentioned tying the shaft off to something and pulling away from it and then said that would not work as the shaft stays in. Is there a way to turn/twist the quill? I looked at getting a large chain wrench to try to turn it. Any suggestions and thank you in advance.
Les8N
:welcome:Try posting on the john deere forum.
Thanks. Is there an FAQ? I am having a little difficulty finding my way around.
1968 CHEVROLET C10 1/2 TON PICKUP TRUCK (A52576)
1968 CHEVROLET C10...
2018 JLG 3246ES 32ft Electric Scissor Lift (A51691)
2018 JLG 3246ES...
2019 Bobcat T590 Compact Track Loader Skid Steer (A51691)
2019 Bobcat T590...
Caterpillar 56in Excavator Bucket (A51691)
Caterpillar 56in...
2008 Sterling Bullet Utility Truck, VIN # 3F6WK76A88G352277 (A51572)
2008 Sterling...
GOODYEAR SET OF 12.4/11-24 TIRES WITH 5 BOLT HUB WHEELS (80% TREAD) (A53472)
GOODYEAR SET OF...
