JD 1020 Hydraulic pump rebuid
   / JD 1020 Hydraulic pump rebuid #1
wcSteve
Bama
JD1020.....JD5425
Hello Forum Folks, (new here by the way)
I'm looking, searching for correct parts and information for my old Hydraulic pump?
Looking at year made and such, it appears I could have one of two different shafts... Which also means possible bushings or needle bearing for my situation.
So help me out if you can based on these numbers: Tractor #4R1C-030825T (year1966, I think)...The number for pump I see today is AR103033...The shaft could be a #R39177 on earlier models, or # R39319 which appears to be a little later... I think the 39177 uses bushings and 39319 has needle bearings????
I have not disassembled my pump yet, but I do know it has been rebuilt before... Now wondering if it even has the correct shaft and or bushing/bearings?
Is it possible to interchange the shafts and bushing, bearings to kind of up date??? If I were to want to, or need to, based on parts available?
I guess that is enough info to get this thread rolling, so fire away,
Steve
   / JD 1020 Hydraulic pump rebuid #3
Steve
Welcome to TBN
IMHO the only correct way to answer your question is if you can provide a number that is cast into or stamped on the existing pump housing. The hyd pump could have been changed out from original pump after tractor was built in 1966. From briefly viewing 1020 parts catalog I think bushings for shaft can't be substituted for brgs utilizing same pump housing but definite answer would require some more parts catalog research. I just checked spec's on bushing & bearings. OD of bush is 1.12'' & OD of brg is 1.312'' so the 2 parts will not easily interchange
2013 Ford F-150 Ext. Cab Pickup Truck (A50323)
2013 Ford F-150...
2015 Ford F-550 Crew Cab Mason Dump Truck (A51692)
2015 Ford F-550...
2012 Freightliner M2 106 Asphalt Pothole Patcher Truck (A51692)
2012 Freightliner...
2019 JGL 2632ES 26ft Electric Scissor Lift (A50322)
2019 JGL 2632ES...
MCELROY PIPE FUSION MACHINE (A52472)
MCELROY PIPE...
2012 RAM 5500 (A52472)
