Nov 11, 2015 / JCB 1400B hyd fluid looks milky like water is in it? #1 J JCBmy1 New member Joined Nov 11, 2015 Messages 3 Location Stedman, NC Tractor JCB 1400B Fluid in sight glass looks a light tan color.
Nov 12, 2015 / JCB 1400B hyd fluid looks milky like water is in it? #2 Tx Jim New Member Joined Jan 26, 2007 Messages 10,280 Location Coyote Flats,Tx Tractor JD 4255/Kubota M7040 HDC Check to see if hyd reservoir breather is plugged. If breather is plugged moisture has no way it can escape when machine gets to operating temp.
Nov 13, 2015 / JCB 1400B hyd fluid looks milky like water is in it? Thread Starter #3 OP J JCBmy1 New member Joined Nov 11, 2015 Messages 3 Location Stedman, NC Tractor JCB 1400B Thanks for info & I will check it out.
Nov 14, 2015 / JCB 1400B hyd fluid looks milky like water is in it? #4 I ishiboo Platinum Member Joined Feb 1, 2011 Messages 994 Location Oshkosh, WI Tractor Kioti NX6010HSTC, Cat 279c Take some fluid out, allow it to settle... see if it separates?
