JCB 1400B FUEL TANK OUTLET PIPE SIZE AND THREAD
   / JCB 1400B FUEL TANK OUTLET PIPE SIZE AND THREAD #1
TX2160
shreveport, LA
Bolens/Iseki TX2160
I would like to put a fuel shut off valve right below the fuel tank on my jcb 1400b backhoe. Real pain to clean sediment bowl and change fuel filter with no way to shut the fuel off. If you know what size the pipe and what thread is used on the pipe I can add a female to male inline cut off valve just below the tank. Thanks please help!!!
   / JCB 1400B FUEL TANK OUTLET PIPE SIZE AND THREAD #2
I don't know the JCB specifically, but would expect it to use BSPT thread rather than the US style NPT.
Difference is slight; the BSPT is 55 degrees vs US 60 deg. They are same thread per inch, so will begin to thread but never fully and will always leak.
The trick is to use a BSPT to NPT adapter nut and then you can use any of a range of US made fuel valves. Adapter nuts are available at some hardware stores, or at lots of automotive stores since most Japanese cars use BSPT for threads into the motor block. Probably also at Mcmaster-Carr.
Luck,
rScotty
1999 Yamaha G16A Utility Cart (A52377)
1999 Yamaha G16A...
2008 DOOSAN G25 GENERATOR (A52472)
2008 DOOSAN G25...
JOHN DEERE 333G SKID STEER (A52705)
JOHN DEERE 333G...
2016 CATERPILLAR 336FL EXCAVATOR (A52705)
2016 CATERPILLAR...
KSI Conveyor (A53473)
