Jason Boling
   / Jason Boling #1
jasonlucia
Montana 4344HST.
PTO switch has 3 positions. Off (right), Independent (missle) and On (left)
Tractor will not start unless in middle independent position. When in this position PTO does not turn or engage. The off position does absolutely NOTHING. PTO only engages in the "On" position.
What is the purpose of the independent and off position and what is the independent SUPPOSEd to do.
Thanks.
   / Jason Boling #2
"independent" position should spin regardless of clutch pedal being pressed or not
"on" position should spin only when clutch is NOT pressed
"Off" is off and should be the position that allows ignition on the tractor
hope this helps.
   / Jason Boling
But it is a hydrostat tranny. How does that work with a hydro tranny?
   / Jason Boling #4
I fought the same problem the second day of ownership;
The label is wrong; if you look in a Montana manual (somewhere) you will see the same switch but the off and independent reversed; or the symbols showing this fact
I use it as a safety feature, Key out, switch to off-- looks OK but tractor wont start
Set of AG R4 Wheels and Tires (A52748)
Set of AG R4...
2022 JOHN DEERE 410E II (A52472)
2022 JOHN DEERE...
2019 DODGE RAM 3500 (A52472)
2019 DODGE RAM...
2013 INTERNATIONAL MA025 ROUSTABOUT TRUCK(INOPERABLE) (A52472)
2013 INTERNATIONAL...
2008 FORD F-350 (A52472)
2008 FORD F-350...
