Jansen Earth Drill Hydraulic Auger
   / Jansen Earth Drill Hydraulic Auger #1
HobbleCreek
Utah
John Deere 4720
I'm wondering if any of you have tried this post hole digger. Hydraulic earth drill Jansen HBG-200 Auger - Jansen USA
I've tried a regular three point hitch mounted PHD and it's just not got what it takes to get through my rocky soil. I'm looking for an effective solution as I've got quite a few holes to dig.
   / Jansen Earth Drill Hydraulic Auger #2
I have a JD hydraulic auger built for skid loaders that appears to be several times bigger than your link. If the point on my auger happens to find a small, say 3" across rock, it will stop all progress immediately, even if it's only a 1/2" thick it will only spin on top of that little rock. If I'm lucky and wiggle things around I might "kick" it up and get going again, but it doesn't take much of a rock before I need a digging bar.
With a more commercial type auger, I could go out and buy a rock auger, probably for just under $1000. I'm doubtful that you'd be able to drop by a local heavy equipment dealer and find augers for that unit or that it could handle it, and also didn't notice any gear reduction either. The motor appears to be directly coupled to the drive connecting point.
Depending on your definition of "rocky" I wouldn't risk the $1000.
All of my comments included having down pressure.
I'd suggest renting a SS with an auger for a weekend and make your own decision based on your success. I hate popping a guy's bubble, but these are my experiences and spending probably a bit less than half of what that little auger would cost you for a days rent, hopefully you'll at least have a bunch of holes at the end of the day. 👍
   / Jansen Earth Drill Hydraulic Auger #3
I have been considering something similar for my backhoe stinger. Danuser comes to mind. There is another similar brand as well, I just don't remember their name right now. Shop around. And weight your options. B.
2014 RAM 4500 versa LIFT bucket truck (A52377)
2014 RAM 4500...
1993 International 4900 Flat Dump Truck, VIN # 1HTSDPNM9PH489370 (A51572)
1993 International...
2018 FORD EXPEDITION (A51406)
2018 FORD...
2015 Ford F550 Bucket Truck - Altec AT40M Boom - Powerstroke Diesel - Automatic Transmission - 4X4 (A53472)
2015 Ford F550...
Generac 5000Watt Heavy Duty Diesel Generator (A51691)
Generac 5000Watt...
SCHAFFER 2430SLT LOT NUMBER 150 (A53084)
SCHAFFER 2430SLT...
