Jammed winch cable
   / Jammed winch cable #1
fruitcakesa
Veteran Member
CavendishVT
M6040 JD 450C
I went to replace the winch cable on my Norse 450 and discovered the old cable is deeply buried in the lower wraps
and when I tried using the tractor to pull it free, it just about stood the tractor up on the rear wheels. So it is truly buried/jammed on the drum.
I have both winch covers off and can see the mess but can't get any type of tool in there to try and free it as there is too much in the way.
Anyone have an idea of a game plan to get it off; remove the drum?
   / Jammed winch cable #2
Cut off wheel in a side grinder... Cut your way in until you get it all out.
SR
   / Jammed winch cable #3
Or a torch. Which has the advantage of "welding" the cut strands together making the pieces much easier to handle.
   / Jammed winch cable #5
I went to replace the winch cable on my Norse 450.. when I tried using the tractor to pull it free, it just about stood the tractor up on the rear wheels. So it is truly buried/jammed on the drum.
You did put the winch in "free wheel" or "Free spool" mode when you tried to pull it out with the tractor, right? I can't believe it's that tight.
I got it out:).
I removed the vertical strut that was blocking the side of the spool and had enough room to pound, pry and lever on the "looped over" cable until there was slack that enabled the trapped kinked cable to slide out.
Then I was able to unspool the rest of the cable with a bit of a fiddle to get the kink through the rear pulley.
New cable went on smoothly and I am heading back to the woodlot.
2011 Manac 36245B30 45FT T/A Walking Floor Trailer (A50323)
2011 Manac...
Split Weight & Wheel Weight (A50515)
Split Weight &...
AGT Agrotk 680 Drop Hammer Attachment (A47384)
AGT Agrotk 680...
2013 Infiniti JX35 AWD SUV (A50324)
2013 Infiniti JX35...
Tye 4 Shank Taratill (A50514)
Tye 4 Shank...
2012 Freightliner M2 106 Asphalt Pothole Patcher Truck (A51692)
2012 Freightliner...
