jammed spare tire winch assembly
   / jammed spare tire winch assembly #1
project
Bronze Member
Northern CA
Used my spare tire lowering winch once and jammed it. It will not lower (minus tire) I have a Ford 350 SD. Any ideas on how to free it?? thanks
I will never make the mistake ,again , of winching it up without the tire. I put the flat tire in my bed to have repaired
   / jammed spare tire winch assembly #2
The cable has probably unspooled enough to jam it up. You are probably going to have to climb under and work with it while someone else lets it down. JC
   / jammed spare tire winch assembly #3
If the cable has unwound inside the winch assembly, there is typically no way to free it. If you truck is still under warranty, take it back to the dealer, they should replace it for free. The same thing happened to my last F350 and the dealer replaced it under warranty.
Ford F250 Pickup Truck (A51694)
Ford F250 Pickup...
2121 (A51244)
2121 (A51244)
2007 Ford E-450 Super Duty 16ft Portable Office Truck (A51692)
2007 Ford E-450...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A53472)
80in HD Tooth...
Tractor Pallet Fork Frame (A51573)
Tractor Pallet...
2022 FORD F-150 XL EXT CAB TRUCK (A51406)
2022 FORD F-150 XL...
