laurencen
Veteran Member
- Joined
- Feb 19, 2007
- Messages
- 1,182
- Location
- saskatchewan Canada
- Tractor
- Bobcat Toolcat 5600T Kioti CK20, Cat D2 dozer, Cat 420 tractor loader, Deer 644E loader, Bobcat E32 mini and Bobcat 590 skidsteer, Toro Groundsmaster 325D
morning all, have a Jacobson HR 5111 mower, has the 2 wings and cuts a 11 foot swath, this has ben a workhorse for 8 years, this year it was low on hydraulic oil, got it to my workshop and topped it up only had 2 pails, its still low and picking up more oil today, problem is it runs for a half hour, then just sitting at cutting speed it will stall out, makes no difference if you are moving, turn on or off the blades, it will start right back up and continue to run but eventually stalls out.
its powered by a Kubota diesel, the motor seems OK its more hydraulic like the motor is under heavy load, any ideas? I doubt the low oil is the issue but maybe overheating.
Im using AW32 oil and assume this is OK for this machine
thanks in advance
thanks in advance
