I want to replace the tires on my car hauler trailer and it seemed difficult to jack up a wheel with an empty trailer sitting on flat pavement using a small hydraulic jack, I cannot imagine doing this task on the side of the road with a vehicle on the trailer with a flat tire. I put the jack directly under the axle and had just enough room to pump the jack handle under the trailer, so a flat tire situation would really be tough. Is there a good jack design for tandem axle trailers that sit low to the ground? My springs are bolted under the axle so the trailer bed sits low to the ground. I prefer jacking on the axle or the spring u-bolt plate so that the tire is lifted directly and not jacking the side of the trailer so high the tire lifts from the ground. I think I read somewhere, probably on this site, where you can drive the good tire up on a ramp or block when it is attached to the tow vehicle and that might lift the flat tire off the ground but I really don't remember if that is correct. What is your solution?
