J2030H hydrostatic tranny/hydro fluid change
   / J2030H hydrostatic tranny/hydro fluid change #1
kompostking
MA
LS J2030H
Hey all just a quick few questions. Ive hit about 100 hours and want to change the fluid in my trany but I have no LS dealers around Only JD and Kubota what would be an acceptable fluid to replace my hydrostatic transmission fluid with. im assuming this is also doubles as the hydraulic fluid running through my loader.
And are there any cross references to different available tranny and hydraulic filters since there is no dealer around.
and what is an acceptable alternative for the fluid in the front end as well.
Thanks Guys
   / J2030H hydrostatic tranny/hydro fluid change #2
Any hydraulic transmission fluid (regardless of which dealer you purchase it from) should suffice. For the front axle, 80w-90 is what is recommended, and is easy to find (as is hydraulic fluid) at TSC or similar. Filters, someone here has already criss referenced them I believe.
You could also check with the nearest New Holland dealer for parts, I believe they use LS for their SCUT line as well.
   / J2030H hydrostatic tranny/hydro fluid change #3
I like the synthetic or semi-syn 75w-90 in the front axle. It seems to have a much quicker flow rate, especially on those zero temp mornings. Those axles on these little tractors just don't take a lot, so it isn't a wallet buster at all. A good quality Universal Tractor Hydraulic fluid is available everywhere, WalMart, TSC, farm stores, etc.
You can go on Wix dot com and or NAPA and see if they have your trans/hydro filter. Unlike the fluid, those filters are highly specialized and some are only available at a dealer. Since New Holland used that same tractor (as did several others in different colors and decals), it should not be too hard to locate.
   / J2030H hydrostatic tranny/hydro fluid change #4
LS had told us to put in a low temp HYD fluid in the HYD system. For the J2030H what we use here is Castrol Trans-c. Its a High Performance powershift fluid.
so in other words order OEM filters One more quick question i change the hyd fluid when the tractor is dead cold with all the pistons relaxed correct? I dont have to warm the fluid up at all.
   / J2030H hydrostatic tranny/hydro fluid change #6
subscribed since only 45 more hours and I have the same task on the same machine--
   / J2030H hydrostatic tranny/hydro fluid change #7
My dealer told me to buy Universal Transmission Fluid at the local Sam's club, because it worked perfectly, and was less expensive. I reminded him I'm not trying to save any money on fluids/filters, and insisted it was absolutely fine, so that's what I went with.
You can now find OEM filters online:
LS J2020H J2030H 5 Piece Filter Maintenance Kit | eBay
BE 3 pt Snow Blower (A50514)
BE 3 pt Snow...
2017 Bad Boy Outlaw XP 61in Zero Turn Mower (A48082)
2017 Bad Boy...
2019 Bobcat E32i Mini Excavator (A50322)
2019 Bobcat E32i...
2024 Ford F-350 Super Duty XLT FX4 - Like-New, Loaded, Only 780 Miles (A52128)
2024 Ford F-350...
1989 Freightliner Cabover FLA086 (A52128)
1989 Freightliner...
Toro Workman Low Profile Spray system 200 (A50322)
Toro Workman Low...
