j series questions
   / j series questions #1
twoodard04
clyde ny
in market
Im thinking of changing up my plans and going with a smaller tractor for day to day yard work. ive used a BX2370 with loader and MMM and was very pleased with it. I priced one today and was pleased with the cost. so my question is how do the j series compare and what are the prices like? are you happy with yours? how is it set up? I like the pedal configuration better on the LS hydro vs the kubota hydro but that would not be a deal breaker. the LS site leaves alot to be desired
   / j series questions #2
The J series is bigger and heavier than the BX. You get dual hydro pumps versus the single on the BX as well as a significant amount more lift capacity with the bucket. Not to mention a better warranty. Think of the J series as being more comparable in size to tyne Kubota B series.
I own a J2023. It was recently replaced by the XJ2025 tier 4 model. I paid $12,200 for mine, but I think think the new XJ models are a little higher. I'm very happy with mine. I've been using it to haul dirt and have moved close to 15 tons in the last couple days. I moved 30 tons of gravel with it last year. It will work circles around a BX Kubota.
Are you happy with the xj so far? What do you use it for?
   / j series questions #4
I don't have the XJ. I have the J2023 which is the same tractor essentially prior to the tier 4 stuff.
I use the tractor all the time! I brush hog 6 acres. I blade a gravel drive. I plow snow my a lot of my neighbors. I move rock and dirt. I use the bucket to lift and move heavy things. I have a rototiller and till my garden my neighbors.
Anyone mowing with the mid mount? Looking for how the fight is controlled
2013 Honda CR-Z (A50324)
2013 Honda CR-Z...
2021 GMC SIERRA CREW CAB TRUCK (A51406)
2021 GMC SIERRA...
2015 MACK GU713 DAYCAB (INOPERABLE) (A50854)
2015 MACK GU713...
2007 John Deere 4320 Cab 4wd (A51039)
2007 John Deere...
2017 UTILITY VS2RA 53FT REEFER TRAILER (A51222)
2017 UTILITY VS2RA...
2017 FREIGHTLINER CASCADIA (A50854)
2017 FREIGHTLINER...
