Thank you for past responses. J Deere 4300, 2001 model, 1100 hours
1. Starting problem. Had no start problem 9-10 years ago, and it resolved itself. Now, have had the issue again, intermittently. Turn the key, cranks like a bandit, no start. Keep trying and eventually fires up and runs normally. After the repeated attempts, it fires up with little or no smoke, and so I assume the fuel solenoid is acting up, not allowing fuel flow. From what I can see the solenoid is located on the injection pump. I see generic replacements are very cheap. Is it an easy install, or am I missing something? I've seen comments about a thermistor, but not sure is my 2001 4300 has one??
2. Gauges. Temperature gauge is all the way over to hot, can get it back by banging on side of cluster surround, but it goes back as soon as I start. Would it be the gauge or sensor?
3.Tires. The front tires are worn out again. This the second set after 1100 hours total. They are the Carlisle Track Chief, as original. I see there are skid steer tires by Yokohama that may be radials. Any recommendations on better tries for the tractor. No problem getting Carlisle again, and will use tubes, just wondering if there is something better, either life or traction.
Thanks for your help in advance.
