j.d. 955 mid mount mower removal
   / j.d. 955 mid mount mower removal #1
StrmChzr
Spring Hill, KS
1995 JD 955
i've never removed my 955's mmm and don't have an owner's manual handy. /forums/images/graemlins/mad.gif
can anybody help?
   / j.d. 955 mid mount mower removal #2
My neighbor has your combination. I know it is pretty easy to take off but I am not sure I can help you. If you put your quetions in the John Deere owning and operating forum I think you will get an answer quicker. Also welcome to TBN you can find all kinds of information here.
murph
   / j.d. 955 mid mount mower removal #3
Going from memory
Disconnect the PTO.
Lower the deck as far as it will go.
Rotate the handle thingy at the front to release the tension.
Undo the hangers from the deck lift mechanism.
Undo the 2 front rods that support the front of the deck
Remove the handle thingy bracket at the front.
Slide the deck out to the side.
Before I start, I usually rotate the rear guage wheels 90 degrees so that the deck will roll out easily.
2015 Ford Escape SUV (A50324)
2015 Ford Escape...
2009 Trail King TK110HDG-523 RGN 66 Ton Tri-Axle Lowboy Trailer (A52377)
2009 Trail King...
2016 Chrysler 200 Limited Sedan (A50324)
2016 Chrysler 200...
2001 INTERNATIONAL 2574 6X4 DUMP TRUCK (A51406)
2001 INTERNATIONAL...
2025 Mower King SSECAG-Y (A50123)
2025 Mower King...
1995 Mazak VTC-16B Vertical Traveling Column Machining Center (A51691)
1995 Mazak VTC-16B...
