J.D. 750 Shuts off?
   / J.D. 750 Shuts off? #1
craig451
John Deere 750
I have a J.D.750 Shuts off as it gets to operating temp, like it runs out of fuel. Thought I was onto something when I cut out the injectors and #3 did not change, so new injector and nothing. I checked a little more and noticed that there is no fuel return and the fuel delivery seems low. Fuel injection pump? Anyone had same issues?
   / J.D. 750 Shuts off? #2
When it shuts down, can you restart it immediately? If not, how long do you wait? Have you checked the flow of fuel out of the tank? I suspect a restricted flow, maybe dirt in tank or fuel line. I assume you have changed the filter?
I'm an idiot, I posted that it was a 750, it's a 950. Don't type with a 20month crawling on your head.
I thought about the tank supply today, but have not had a chance to check it and yes the fuel filter was the first thing replaced.
You can crank it back up, but it shuts back down with in seconds, depends on how hot it is, as I said before like it's running out of fuel. It acts as if it is running out of fuel, so you may be onto something. I'll check it and let you know. Thanks!!!
VERMEER RTX 130 WALK BEHIND TRENCHER (A51242)
VERMEER RTX 130...
2017 GENIE GS-2646 (A52472)
2017 GENIE GS-2646...
2013 PETERBILT 365 T/A DUMP TRUCK (A51406)
2013 PETERBILT 365...
2016 Big Tex 24ft. T/A Flatbed Trailer (A50322)
2016 Big Tex 24ft...
2013 BIG TEX PRESSURE WASHER TRAILER (A52472)
2013 BIG TEX...
2015 INTERNATIONAL MA025 (A52472)
2015 INTERNATIONAL...
