Oil & Fuel J.D.750 injection pump removel
   / J.D.750 injection pump removel #1
rundogs
Hey guys,new to the site so bear with me.I am trying to get running a J.D.750 that has been sitting outside for a few years.I freed up the engine,removed and cleaned the injectors,but here is the problem.The injector pump is gummed and froze up and I cannot remove it from the housing.The rack on the pump is stuck alway forward and will not allow it to clear the opening in the housing.I have soaked it for weeks,pryed on the rack, but it will not slide.The rack will rotate in place,but will not slide.Is the rack mechanicaly held in place or just stuck?Any experiance or ideas would be appreciated.
   / J.D.750 injection pump removel #2
The rack just twists the pump's valving mechanisms when it slides back & forth. My guess is that, if the rack itself is free, that the threads on the individual valves are rusted or gummed up or something is wedged into one of the gears. I dont have a good suggestion on how to free them though.
images
Aaron
Hoye Tractor Parts
Contact Us
(940)592-0181
Aaron,Thanks for the photo and the info.Now that I know the rack should slide,I might try to heat and bend a small pry bar at the correct angle and drive it in as a wedge between the rack and the housing.It just such a tight fit in there.
It worked!A bend, a few grinds on a HF pry bar and a few taps with a hammer and the rack moved enough to remove the injection pump.
2025 New/Unused Wolverine Clip on Pallet Forks (A51573)
2025 New/Unused...
Chery 7' 35 Drawer Workbench (A50120)
Chery 7' 35 Drawer...
UNUSED RAYTREE RMBD72S-72" DRUM MULCHER (A51248)
UNUSED RAYTREE...
BUSH HOG 7007 LOT NUMBER 115 (A53084)
BUSH HOG 7007 LOT...
2011 Kia Sportage SUV (A51694)
2011 Kia Sportage...
2018 Ford F-550 Flat Bed Truck, VIN # 1FDUF5GTXJEC35552 (A51572)
2018 Ford F-550...
