J D 2840
   / J D 2840 #1
kuntryjake
I just bought a 2840 . The lift & loader puts a strain on motor when you operate eather one. After a while in operation you get a jerking movement as you operate.Is the valve sticking or pump bad?
   / J D 2840 #2
You should get that thing into a good dealer to do pressure and flow testing. Chances are there is a high pressure leak some where in that system. It's a closed center system which doesn't pump oil until it senses a pressure drop. 30-40-50 series were notorious for these. It wasn't until the 55 sereis they finally got everything or close to ironed out.
2842 (A54756)
2842 (A54756)
2007 FORD F550 XL SUPER DUTY DUMP TRUCK (A51406)
2007 FORD F550 XL...
2012 DOOSAN G25 GENERATOR (A53843)
2012 DOOSAN G25...
2019 Caterpillar DP35N 7,000lb Diesel Forklift (A55851)
2019 Caterpillar...
1967 Ford F100 (A47477)
1967 Ford F100...
2021 Toyota Corolla LE Sedan (A53424)
2021 Toyota...
