J.D. 1070 compact drive shaft problem
   / J.D. 1070 compact drive shaft problem #1
Thibs53
Rumford maine
John Deere 1070
Thibs23 here and new to the sight,
Have a tech question about my 1996 J.D. tractor, Heard grinding noise in my 1070 around the MFWD drive shaft area , removed drive shaft and found 8 of the 12 steel balls missing and needing replacement, looks like the 12 steel balls and the 2 rubber boots should be replaced, are there any other parts that are recommended to be replaced when this problem occurs. Upon inspection, I see nothing worn or destroyed, wondering if the seals should be changed? Thanks in advance!
   / J.D. 1070 compact drive shaft problem #2
:welcome: to TBN.
Do you have the service tech manual for that tractor?
:welcome: to TBN.
I do but I does not say much about suggestions of part replacement other than what is obvious, wondering if the seals should be changed, and/or anything else?
CONTAINMENT SKID MOUNTED (A53843)
CONTAINMENT SKID...
2010 Ford Crown Victoria Sedan (A51694)
2010 Ford Crown...
43030 (A51691)
43030 (A51691)
MONITOR WITH BUILT IN COMPUTER (A53843)
MONITOR WITH BUILT...
2022 Club Car Tempo Cart (A51694)
2022 Club Car...
2010 John Deere TX Gator 4x4 Utility Cart (A52377)
2010 John Deere TX...
