Its all down to fuel consumption
   / Its all down to fuel consumption #1
fredkos
Am looking at both the Kubota GR2110 and John Deere 534/530 not that much of a difference-about $800- between the two. Deer dealer is of course asking full price, even when I was the only person in the showroom this Saturday afternoon, the Kubota dealer really wants to move one that is on the floor REALLY wants to move it.
I could get by nicely without awd, in fact the Deere with the 4 wheel steering and diff lock is the best decision on paper-I do like to keep things simple.
Just how -bad- fuel consumption wise are the 25hp kaws and is there really any compelling reason to spend the extra dollars on the liquid cooled version.
Info greatly appreciated.
I did try to search but no luck getting what I am looking for.
   / Its all down to fuel consumption #2
I can't speak to the Deere, but the fuel consumption on the GR2110 should be very good, I have the 2100 and fule consumption is excellent. That said, I would go for the Deere for several reasosn.....in a nutshell, I have had nothing but trouble with the GR. There are others on here that will tell you they have had no trouble with theirs at all so maybe it's just me. Good luck with your decision
Chris
Chris, thank you for the reply. If you could give any details on your Kubota experience it would be very appreciated as I will be buying something by the end of this week. Of particular interest, besides problems, is just how long can you mow on a tank of fuel and in -general- are you satisfied with the the 3cyl diesel? Personal issue, really bad back-installed one too many boilers- does make the Kubota and its suspended seat attractive.
And if I am lucky someone with first hand experience with both a liquid cooled Kawasaki and an air cooled Kawasaki engines could help me out. I have read a little info that indicates both are hard on fuel, but no real specifics.
But when the Deere dealer himself says that he would NOT buy the liquid cooled engine it does get you wondering..
Tnks again.
   / Its all down to fuel consumption #4
I have no problems with engine at all. IT's a little loud, but it runs well and there is plenty of power. My problem is that it has about 134 hours on it and seems to spend more time in the shop then anywhere else. Mostly for transmission and related problems. My main complaint is that it leaked and for a machine of this calibur, the transmission is very weak. Kubota had some known issues with the first generation trannys in these things....primarly the fact that they used bushings instead of bearings for the rear axles. That has since been corrected and the newer ones have bearings. The bushings isses caused a lot of leaking after they got a few hours on them. Mine was upgraded after I had it in about 5 times and when I got it back, it was still leaking. It went back and has not leaked since, but I hve only put a few hours on it since...the machine only has 137 hours on it total. They have already had to replace the glide steer cables as well, but they have redisgned the mounts for the new ones so in theory they wont break again..... at 120 hours. My main complaint now is the the the trasnission is incabiable of delivering the power to the ground. It , in my opinion is very weak. I do not advocate spinning he tires over on a tractor just for grins and giggles, but if it gets into a bind....(pulling a cart, pushing snow...whatever) it should have the cabibility of spinning the tires. Otherwiser how does one know if the all of the aviable power is being delivered to the ground? Mine just sits there and whines. For a machine that cost 8K, I expect more then that. As far as fuel ecomany goes, I have and 18hp gas gravely that uses three tiems the fuel of this Kobota given the same work load......but, it also handles said workload nuch better.
If all you're after is cutting grass economicly and reasonably quickly, with all the improvments that have been made, the Kubota might be a good choice, but if you're wanting anything else and mine is representative, I would go with something else. The last time mine came back from the shop it was in there for the sole purpose of the Kubota rep to go over it and and make any necessary adjustments. When it came back to me his words were, "it pulls as well as any GR out there". I haven't really had a a chance to find out yet, but I guess we'll see.
There are others on here that are totally satisfied with their GR's. There is one guy who has made many very nice attachments for his and he loves it...maybe he'll put in his two cents worth. Maybe i got a bad one, but I am a long way from being satisfied. Good luck with your decision.
Chris
Chris, one last question for you; you sound as if your machine is a couple years old but I still think it has the seat with the twin shocks, just how comfortable is it over the bumps-will it bottom out much?
Tnks again
   / Its all down to fuel consumption #6
The new GR's have an adjustable spring tensioned seat that should be better a better ride than the older GR's like mine and Chris's.
That said,if I were looking at new tractor today and had no use for 4WD,I would look at a new Simplicity.I've had three of them and the cut can't be beat imho,plus the decks are lighter and easily removed and will stand on their tail for easy maintenence like blade removal/sharpening.
Nothing can match a Simplicity for cut and for ease of getting the deck on and off, I owned one for 15 years. Problem is that I did not even get 500 hours out of the Briggs Vanguard twin, never again.
   / Its all down to fuel consumption #8
What locknet said about the seats is absolutly true...I hope the newer ones are better....
   / Its all down to fuel consumption #9
Fred I was at the John Deere dealer and he offered me a new 2009 540 with 54" deck, Kaw water/air cooled engine for $6500. I almost bit, but want a small diesel lawn cutter. He also said that Deere maybe reviving the old 355d, with an up dated possible 3 cylinder diesel.
   / Its all down to fuel consumption #10
I don't have much to compare the LC Kawasaki to and have never paid much attention to fuel consumption on a lawn mower, but those LC Kawasakis are quiet...real quiet for a lawn mower engine. Dad has a JD 345 with ~300 hrs on it (no problems) and when he's mowing the loudest thing you hear is the mower deck. You can have a conversation with someone without too much diffculty even at full throttle if you want. The noise difference in his LC Kawasaki and my Kohler Command V-twin is like night and day.
2018 WACKER NEUSON RTSC3 ROLLER (A53426)
2018 WACKER NEUSON...
New Bulk Lot Chain Slings (A53002)
New Bulk Lot Chain...
Generac 5000Watt Heavy Duty Diesel Generator (A51691)
Generac 5000Watt...
2019 RBR Venturi 380 (A52748)
2019 RBR Venturi...
NEW Wolverine 72'' Skid Steer Tiller (A53002)
NEW Wolverine 72''...
