It was a hoe down!!
   / It was a hoe down!! #1
First one
Eastbrook, ME.
08' Kubota L3240 HST /cab
Ya.. Here's a good one for anyone trying to use your hoe to get unstuck. I didn't want to post this stupid mistake I made but thought that if I could save someone else from making it then I could live with the humiliation, here goes.:ashamed:
I was using the cat 416 backhoe at work and got stuck, so I still had the hoe to try and get out with. I had been trying to back out when I spun around in the seat , put my stabilizers down ,but not to the ground. I reached over cranked up the rpm's and reached out with hoe and started to pull myself out when I noticed that all of a sudden I was in the air balancing on the hoe with both back tires off the ground about 1 1/2 ' ( pucker factor running very high ) I quickly pushed the hoe out and the tires came back down as I pushed myself back to were I was in the first place. As I was in the air I noticed the back tires were spinning .
Why? DUH In my rush to get out, I never took the backhoe out of reverse when I turned around and cranked up the rpms to about 1500 to use the hoe , and was trying to pull myself out the front tires got traction and was pushing the backhoe right back on the hoe, which in turn lifted the rear tires up. I know stupid!!
But just thought that any of you trying to get out with your hoe "be aware" if your in gear or not. I could see it going over on its side pretty quick if I hadn't pushed back out on the hoe so fast , at that point the stabilizers wouldn't save you from going over. Just when you think nothing can go wrong voila :ashamed::ashamed:
CATERPILLAR 312E EXCAVATOR (A52706)
CATERPILLAR 312E...
2017 FORD F550 XL BUCKET TRUCK (A51406)
2017 FORD F550 XL...
2015 MACK CHU613 DAYCAB (A53843)
2015 MACK CHU613...
2018 INTERNATIONAL 4400 4X2 EXT CAB SERVICE TRUCK (A51406)
2018 INTERNATIONAL...
2017 Kubota M5-111D Tractor (A52377)
2017 Kubota...
CHERRY PICKER AND TRANSMISSION JACK (A53843)
CHERRY PICKER AND...
