Ballast It must be a conspiracy.
   / It must be a conspiracy. #1
sbakf
Bronze Member
Columbiana, AL
2010 L5740/cab & BX2660/FEL with 60" MMM
Based on the tractor I own (L5740, first one) and the one I知 about to buy (BX2660), one purchase invariably necessitates another.
Why are tractors of today so unstable? Is it their diminished length and width lest not forget weight. Granted, all tractors need add-on implements to make them useful and it痴 a plus that each attachment lends some added stability to the platform that carries it. What bugs me though, is why it seems that each implement must be counterbalanced by another. Case in point - dealer called me about my BX2660 with 60 MMM and attached 42 rotary cutter. He suggested that I go ahead and add the FEL to my purchase to counter the weight of the RC. Seems the BX got awfully light up front with RC attached. I tested it today. Yep have to agree. I stood on a slightly raised RC and the front wheels on the BX became airborne. A FEL is a rather expensive counterweight a set of front weights would be far cheaper. But - why should I be compelled to buy either?
   / It must be a conspiracy. #2
I'm not sure that tractors have gotten smaller or lighter that recently. The main reason I just got a JD 870 is that I got tired of having to stand up on my '72 Mitsubishi when brush jogging to keep the front end on the ground.
That being said I agree with your point. I think all FEL's should come with a ballast box and you can get a discount if you opt out of the box. But I don't make or sell tractors so I just have to do some smart shopping and always remember to do my own balancing. I keep forgetting it's a ride on adjustable tool not an actual vehicle. :)7
   / It must be a conspiracy. #3
Thinking back to when I was young (in the 60's), my dad had a Ford 9N...No front loader, wide stance and AG tires...With no implements on the 3ph, that puppy threw one heck of a nice wheel stand...The older tractors were built well/balanced indeed, but I'd take todays SCUTs over them...If you don't want to spend the money for a front loader (which I leave on all the time), weights for the front end are a nice/inexpensive alternative.
Don
   / It must be a conspiracy. #4
Funny thing is that I can't imagine a small tractor WITHOUT a front end loader. In my view, the FEL provides half of the usefulness of a tractor. If this weren't the case, my wife wouldn't call it my "30 horsepower wheelbarrow".
Mike
   / It must be a conspiracy. #5
Actually in many cases and especially in the SCUT/CUT sector, I see the need to add counterbalance to be a good indicator of how well balanced they are. On these non Ag focused machines aimed primarily at lawn care minor chores, weight or lack thereof is very important.
Weight has to be pretty evenly balanced front to back and in order for it to handle several hundred pounds hanging off one end or the other weight has to be on the other end whether add on or designed. Since they can't know if a FEL or even a RC will ever be used on any given tractor it is designed to do well absent any attachments.
When you get into Ag sized stuff things change. There is a JD 7210 down at our barn with a FEL that I have yet to see anything on the 3-point.
Hopefully that made sense.
   / It must be a conspiracy. #6
I have a L3240 with NO-- FEL and use it mainly for R cutting and pulling a 7ft disc and box blade work. We put in food plots for our hunting and thats about it. Dealer suggested weights on the front since I op out of the FEL. I have 3- 52lbs and the grill guard so I am guessing 200lbs on the front. WOW what a difference it makes. The reason I say that is because on day I had to try it with NO weights so I spent the 30 mins taking them off and found out what the weights did. Amazing how much just 200lbs makes. I have room for one more weight but really dont see the need right now.
AndyG
   / It must be a conspiracy. #7
I have a BX2660 and I always have A balast box for the rear and 4 suitcase weights (at 55 lbs each) on the front if I'm using either the mower deck or the 3 point the front weights are on and stay on, if I use the FEL I either use a 3 point implement with it or put the weights into the ballast box. I have had a few close calls with either the loader and raising the rear wheels off of the ground (apparently I even at one time had the tractor balanced on just the rear right tire and the other 3 off of the ground) or losing all traction on the front with something on the rear. I have a cab on my tractor and knowticed that it will sway side to side easier but counter balance is a must with this tractor.
BX2660
FEL, 60" MMM, pull 25 gal sprayer, box scraper, rear blade, drag harrow, disk harrow, lawn sweeper, broadcast spreader, ballast box, 4-55 lbs suitcase weights.
   / It must be a conspiracy. #8
I hear what your saying,one could say do to the type land shall be work or more plastic compare to metal also yester years iron long heavy cast engines,maybe lighter low weight less of chance of roll over??? getting so attachment cost almost much as tractor..all most,but it sure beat the heck out of armstrong shovel and pick. ;)
   / It must be a conspiracy. #9
I hear ya too. I knew I wanted the FEL for my BX, but dealer said ballast box isn't really necessary unless I'm loading a lot.. well, i planned to, researched, and instead got a box blade. Now I have 2 implements I can't live without and work great together.
Getting a 50" tiller now too, and dealer said tilling with the FEL on would probably be a good idea as well... lol..
At least with a MMM I can remove everything.. I cant imagine mowing with the FEL on. I've gotten pretty quick at putting things on, taking them off.
   / It must be a conspiracy. #10
Based on your previous post...I've been pouring over the new manuals which are terribly lacking in information. If I'm not mistaken when I was studying Ag Mechanics 109 at Nebraska the manuals were coming out with slope recommendations which I don't see on these tractors.
I did examine the Front Loader manual on my 5740 and the Rollback Force varies with bucket size but very common to all three buckets is the initial force when lifting the bucket from the ground can be as much as 2100 (kN) in the first 1000 millimeters of travel which isn't very high and explains your correct interpretation that your bucket never got over the grill. That's for the LA854 bucket. The LA724 wasn't far behind at around 1700-1800 (kN).
Interpretation in mho is that the moment arm is greatest and critical on any slope when first moving the bucket your first few feet. As the load/moment arm shifts further back the force comes over the center of the tractor. So the first four feet especially on a slope where the tractor is pointed down hill is critical. The only thing the manual shows is not to move a load sitting sideways on a hill (duhhhh). Kubota should definitely have some basic charts for calculating load and slope angles.
If I didn't read TBN posts I probably would have damaged something in the near term.
The fact that these new tractors can lift a ton without any problem
2015 Kia forte (A50324)
2015 Kia forte...
2016 CATERPILLAR 325FL CR EXCAVATOR (A51242)
2016 CATERPILLAR...
UNUSED FUTURE SKID STEER MOUNTING PLATE (A51244)
UNUSED FUTURE SKID...
2019 CATERPILLAR 262D3 WHEELED SKID STEER (A51242)
2019 CATERPILLAR...
2022 KUBOTA KX040-4 EXCAVATOR (A51242)
2022 KUBOTA...
