Posthole Digger It just wont dig
   / It just wont dig #1
feedsack
I started to dig some post holes and depending on where on the property I am I can did one in 10 minutes or it will go down 6 inches and just turn. I have east Texas gumbo soil and its rock hard now but I always seem to be able to dig. What could the problem be?
   / It just wont dig #2
Might need extra weight on the PHD (or down pressure $$$). Someone not too long ago posted a photo of the weight he hung on the end of his PHD. What does the tip of the auger look like... they can get dull. How old is the unit?
   / It just wont dig #3
Teg might be referring to my very temporary proof of concept weight that I put on my post hole digger...
http://www.tractorbynet.com/forums/...w-me-posthole-digger-power-5.html#post2101242
The weight did make a huge difference. I also replaced the digging blades. It that same thread I have a picture of the gravelly soil that the digger went through.
With the new blades and the weight hanging off the back, I dug 16 holes about 4 ft. deep in about an hour. You should be able to get better than 10 minutes for 6 inches. Is the ground too dry?
   / It just wont dig #5
Had the same problem several years ago with fenceposts in 1 foot of topsoil over 12 feet of clay.
The only solution is to do it in springtime or fill the hole with water and wait a couple of days then try again.
2022 CATERPILLAR 926M WHEEL LOADER (A51242)
2022 CATERPILLAR...
(1) 250 GALLON POLY TOTE W/ CAGE (A51244)
(1) 250 GALLON...
Ih 4300 Field Cultivator (A50514)
Ih 4300 Field...
2020 GENIE TZ-34/20 TOWABLE MANLIFT (A51242)
2020 GENIE...
HLA 84" Skidloader Material Bucket (LIKE NEW) (A50774)
HLA 84" Skidloader...
2007 PETERBILT PB335 LUBE TRUCK (A51243)
2007 PETERBILT...
