Was looking on JD Part catalog and saw some mention of a pressure relief and an anti-cavitation arrangement on the dipperstick valve, but did not see any mention of this on the boom valve. I'll have to do some more investigation to see if both the valves are the same or not. If they aren't, it should be a big deal to pull the valve stack apart and swap positions in the stack with the boom and dipperstick valves. I don't have a lot of time yet running a backhoe, so if I'm going to learn... I want to learn SAE as there is some other equipment I may potentially run someday. Seems like most all of the other excavators I may run all use SAE.
