Iseki4270
   / Iseki4270 #1
hayphil
edingthorpe
iseki4270
Just bought this ISEKI 4270 tractor and have been unable to engage 4WD. Is there a particular sequence for engaging 4WD that I am unaware of?
Phil
   / Iseki4270 #2
I had an agco tractor made by Iseki a few years back with the same problem. It was a new tractor and the lever to shift it into 4wd didn't want to move. The dealer said they were tight and would bind a little. He put one hand on the lever and one hand one the shaft the the lever is connected to and pushed in on the shaft while moving the lever. So from then on that is what I had to do to make it go into 4wd.
I don't know if you have the same issue, but you might try it. Good luck!
2017 Ford Fusion Hybrid Sedan (A53424)
2017 Ford Fusion...
Heavy-Duty Gooseneck Hay Trailer - Built for Large Bale Hauling (A53473)
Heavy-Duty...
2013 PETERBILT 365 T/A DUMP TRUCK (A51406)
2013 PETERBILT 365...
2018 Volvo MCT 110C (A47477)
2018 Volvo MCT...
2016 R and R Products 331 LP Reel Mower (A51694)
2016 R and R...
