gilbertmsg
I'm trying to remove the injection pump off my Iseki. It has 3 bolts that are off and lines to head are removed. It will slide out 1/4 inch and thats it. It also can be rotated about 1/2 inch left or right for adjustment. Need to remove pump to replace glow plugs or will have to remove head to get at two of them. Anything holding it from the front side? Any help will be appreciated.
I have manuel and it states to remove the bolts attaching the timing gear case and remove the injection pump assembly. Am I missing something.
Does the crank have to be in a certain position to release the injection pump?
Or does the pump stay attached to the timing gear case and I need to remove the back of the timing gear for inection pump to come off?
Thanks!!
Eddie
Thanks!!
Eddie
