Iseki TS2210 Brake shoes
   / Iseki TS2210 Brake shoes #1
bbrinkley
Gilbert, AZ
2018 JD 1025R TLB, Old Tractor was a Iseki TS2210
Hello all!
I am in need of brake shoes for my TS2210 2wd. The only part number I see is TS20 and JCB1 on the shoe itself. Does anyone know where I can get a set or a compatible set from another brand.
Brian
   / Iseki TS2210 Brake shoes #2
Go to your local NAPA store or a heavy duty truck repair shop and ask them where you can get brakes relined. That means they use the steel frame again and just put a new lining on.
I Would if I could, previous over ran it until the backing plates broke into two. Any ideas if another brand tractor would fit with slight mods?
Unfortunately there is not enough left of the backing plate to do it. It was in there so long most turned into rusted dust. I am amazed how good the drums looked still. I did find some golf cart shoes that appear to be almost identical in size (1/10 of an inch less wide) that I am going to attempt to modify to fit. Will see how that works out. If that does not work then I have plans to convert it to disc brakes. Hopefully though the GC pads work as I would ever hardly use the brakes anyhow.
   / Iseki TS2210 Brake shoes #6
If the other part of the original brake shoe where the hardware goes on is not extremely rusted carefully remove it from the rusted backing plate and after removing the similar part from the GC shoes weld the original to the new GC backing plate. It might work.
Actually found them on a Website/Tractor parts in Poland. The shipped out today after a lot of google translate!
2013 KENWORTH T370 DUMP TRUCK (A51406)
2013 KENWORTH T370...
New/Unused 84in Quick Attach Rock Bucket (A51573)
New/Unused 84in...
2017 CATERPILLAR D6K2 LGP CRAWLER DOZER (A51246)
2017 CATERPILLAR...
1 Bridgestone 255/70R 22.5 and 1 Toyo M-872 12R 22.5 Tires (A51573)
1 Bridgestone...
2017 TRAILSTART 40FT DUMP TRAILER (A52576)
2017 TRAILSTART...
Kubota RTV-X1100C (A51573)
Kubota RTV-X1100C...
