Oil & Fuel Iseki ts1610 hydraulic oil change??
   / Iseki ts1610 hydraulic oil change?? #1
Brandon35
Decatur, alabama
None
Hi guys, I'm not really a new member I lost my password and can't get it to reset so here I am again...
My neighbor has an iseki ts1610 that needs serviced. I wanted to change the hydraulic oil out in it. There are two drains on the bottom of the tractor. One on the transmission and another farther back. I believe I'm suppose to drain both and clean a filter screen that's hiding somewhere.
My questions are:
1) Do I drain from both areas?
2) Do I refill it from the transmission only or do I also have to put it in the reservoir behind the seat? Didn't know if they ran together or not. There is a oil level screw on the side of the transmission area and I didn't know if it was for all area that held the hydraulic oil also.
3) Does it just take 5gallons?
4) Where is the filter screen?
5) Anything I should be aware of prior to doing this?
Thx in advance.
2020 COLOMBO TM LOT NUMBER 218 (A53084)
2020 COLOMBO TM...
(1) 275 Gallons of Aluminum Brightener (A51573)
(1) 275 Gallons of...
2025 New/Unused Wolverine Auger Drive and Bit (A51573)
2025 New/Unused...
2024 JOHN DEERE 4044M LOT NUMBER 65 (A53084)
2024 JOHN DEERE...
2017 Kubota KX080-4 Mini Excavator (A51573)
2017 Kubota...
2007 Freightliner B2 School Bus (A51692)
2007 Freightliner...
